Previous in Forum: P Number   Next in Forum: Mixing
Line Sizing
09/05/2010 4:40 AM
what should be the line size if im recirculating part of liquid to tank and partly to consumer? See my pump flow is 2.0 CMH and my process requirement is 0.5 CMH. Liquid being used is water.
Be not afraid of growing slowly, Be afraid only of standing still.
Re: Line Sizing
09/05/2010 10:45 PM
Hi bhalchandra,
Generally with water flow you'll size lines for 1.5 - 2.0 m/s velocity. In this range you shouldn't have to worry about water hammer issues, nor friction loss (will be minimal at this velocity).
Yuo can go higher than the velocity recomended above, but do so with care. Even up to 3 or 3.5 m/sec should be OK.
Recommend using 2 m/s in your calculations, to find the diameter of the line.
Kind Regards,
Anthony
