Previous in Forum: Ring CT   Next in Forum: Zero Sequence Current & Voltage Measurement
Physical Differences Between 3.5c & 4c Cable
09/06/2010 1:05 AM
what is the physical difference between 3.5c & 4c Cable? where to use?.
Engineering Fields - Electrical Engineering - New Member India - Member - New Member Popular Science - Genetics - New Member Technical Fields - Technical Writing - New Member Safety - ESD - New Member Engineering Fields - Power Engineering - New Member
Re: electric cables
09/06/2010 1:36 AM
phycially 3.5 C will have 3 full size conductor and 1 half size conductor for eg 3.5C X 120 sqmm will have 3 cores of 120 sqmm and last one of 70 sqmm. where as 4 C X 120 sqmm will have all the conductor of 120 sqmm. Fourth core generally meant for the neutral..................... U can use any of them depending upon unbalance load i.e single phase loads and harmonics in the system since each of the above phenomena will lead to heating of the neutral conductor.
Correct Me If Iam Wrong, Suggestions/Recommendations needs to be verified before implementation
Re: Physical Differences Between 3.5c & 4c Cable
09/07/2010 2:04 AM
Same as difference of 34C and 36B breasts.
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
