Previous in Forum: Physical Differences Between 3.5c & 4c Cable   Next in Forum: Busbar Support Distance and Short Circuit Currents
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
Zero Sequence Current & Voltage Measurement
09/06/2010 1:06 AM
If we know the phase currents & voltage at the time of earth fault we can calculate the zero sequence current & voltage easily. Otherthan is there any instrument for the automatical measurement of zero sequence current & voltage which can be connected permanently to the sysytem.
If you can't find a way, make one........
Engineering Fields - Electrical Engineering - New Member India - Member - New Member Popular Science - Genetics - New Member Technical Fields - Technical Writing - New Member Safety - ESD - New Member Engineering Fields - Power Engineering - New Member
Re: Zero sequence current & voltage measurement
09/06/2010 1:48 AM
there are many relays available which can measure earth fault i,e zero sequence either in terms of voltage or current based on the input to the relays either CT or PT input. You can google search for the zero sequence relays.
Correct Me If Iam Wrong, Suggestions/Recommendations needs to be verified before implementation
