Previous in Forum: Multi-Function Numerical Relay for 11 kV Capacitor Banks   Next in Forum: Conveyor Power Saving
Can This Transformer be Used as a Step Up Transformer?
09/06/2010 10:44 AM
A Transformer having 33/6.6 kv 10 MVA rating can v use it as a step up Transformer with same rated power? If no then what is the difference between them???
Good Answers: 244
Re: Can This Transformer be Used as a Step Up Transformer?
09/06/2010 11:34 AM
Yes. The rating 33/6.6 KV doesn't indicate it is step down transformer, it only indicates its HV rating is 33 KV and LV side is 6.6 KV. A transformer itself is not designated as step-up or step-down unless it is used for these purposes. If the transformer's other ratings including the vector group serve the requirement, it is perfectly ok to use.
- MS
09/08/2010 4:04 AM
As Msamad said we can use any transformer for step-down or step-up unless the vector group, frequency and voltage matches, we have to also take care of the Tap changers in the transformer. it also plays a significant role to use.
Good Answers: 170
09/11/2010 9:45 PM
A transformer is a bi-directional device and your 33/6.6kV Step Down Transformer can very well be used as a 6.6/33kV Step Up transformer. But, there could be magnetising in-rush current problems while you charge the trafo from LV Side. Please underake a study of this. Also, take care about Vector Group, Earthing of Neutral, etc.
09/29/2010 1:01 AM
what about onload tapchanger which gets signal from secondary voltage and adjust taps by AVR to maintain a constant secondary voltage within limits?.
pnaban
Register to Reply 4 comments
amarnath.sn (1); electricalexpert65 (1); msamad (1); pnaban (1)
