Previous in Forum: Transformer design   Next in Forum: Bad things happen in threes
India - Member - New Member
Recovering Metal from PCBs
09/06/2010 1:54 PM
Can acetone or propanol dissolve the plastic components of printed circuit board completely,so that metals can be recovered from it,if not is there any other solvent which can do so ?
Re: Recovering Metal from PCBs
09/06/2010 3:15 PM
No. If it were that simple, everyone would already be doing it.
You don't understand the process.
09/06/2010 3:55 PM
OK,give useful advice pilgrim .
09/06/2010 4:00 PM
I'd start by using a search engine and looking at recycling PCB's.
Do your own research. Then, if you ever have a valid question come back here and we'll help. Don't expect us to do all your work for you.
Don't expect to see you back here.
Good luck.
09/06/2010 4:05 PM
Thank you pilgrim for your advice.
09/07/2010 11:29 AM
well you say as if as if you are aware of every aspect of this research.I had asked this if anyone had done this before under any different conditions or with something else and if you are unwilling to answer or preoccupied with any previous ideas then please don't give me your advice.....
thank you
09/07/2010 12:48 PM
OK.
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
09/08/2010 11:36 AM
I recall a discussion a while back about someone trying do this using acid to dissolve all but the metals, but for some reason, I can't find the thread. It's not an easy process, and there are lots of "nasty" things to deal with; bromines, lead, arsenic, etc.
I saw a documentary once where somewhere in China these poor villagers were basically "burning" the boards to recover the metals, releasing all kinds of toxins to the air, not a good place to raise the kids! If you do try to do this, please be environmentally friendly.
Tom D. (a printed circuit board designer and tech)
Register to Reply 7 comments
Anonymous Poster (2); lyn (3); Somnath (1); tdesmit (1)
