Previous in Forum: Load Cell Cale Length   Next in Forum: Instrument Analyzer Responsibility
Bently Nevada 7200 Interface Module BA 38305-01 Possible Sources?
09/07/2010 12:40 PM
Looking for suggestions to substitute a blown signal conditioning interface module in a B-N 7200 vibration monitoring system on a small gas turbine generating package - a full control system replacement is in plan in about 18months time, so we're looking for a quick fix (ideally straight replacement of the failed item only) to keep us going until then.
The part is obsolete, so the OEM can't/won't help.
(Site is offshore gas platform, UK).
Good Answers: 58
Re: Bently Nevada 7200 Interface Module BA 38305-01 Possible Sources?
09/07/2010 2:32 PM
Do you have a spec/cut sheet on the existing module. If so, post it and I will check with some sources here in the US.
I tried to Google "Bently Nevada 7200 Interface Module BA 38305-01" as well as different combinations of the same to no avail.
I can't guarantee anything but I certainly will give it a shot.
09/10/2010 3:44 AM
sorry for slow response, all I have at the moment is the part number read off the device - although not giving correct readings its still in the circuit to keep the system alive. There may be old documentation around, but it will be 20 years old, and I haven't found out where to look yet!
Register to Reply 2 comments
