Previous in Forum: How Much Water is Needed to Rust a Hole in Steel?   Next in Forum: Design Before Degree?
Engine Parameters
03/08/2007 1:24 PM
Sir
Please furnish me to how to determine an effective engine power, including its formulas.
Re: Engine Parameters
03/08/2007 8:19 PM
Basic formulas, using consistent units:
Torque = force x distance
Power = angular speed x Torque
Force = Pressure x Area
Effective power = Nominal power x efficiency
Please be more clear in your question, if you'd like me to help you further.
Humm... suspicious you are...
03/12/2007 12:22 PM
Sir
Further to my request below are the ENGINE DATAS.
ENGINE MAXIMUM POWER = 99 KW
ENGINE RATED SPEED =6000 rpm.
COMPRESSION RATIO = 10.8 : 1
SROKE / BORE RATIO = 88mm /85mm.
MAXIMUM TORQUE 19 da Nm at 4100 rpm
TOTAL PISTON DISPLACEMENT = 1997 cm
MEAN PISTON SPEED = 8.8 m/sec
WHAT IS THE EFFECTIVE ENGINE POWER OF THIS ENGINE?
Please if there's any good literature on this topic, kindly Assist me.
Good Answers: 19
03/08/2007 11:10 PM
Are you asking for heat rate such as heat in / power out?
03/09/2007 3:42 AM
Register to Reply 4 comments
Anonymous Poster (1); bhrescobar (1); PetroPower (1); PWSlack (1)
