Previous in Forum: Frame Size   Next in Forum: Computer Power Supply
Load Sharing
09/10/2010 4:54 PM
Sir,
We have four 500 KVA generator 2 Gen allways use parallal,Gen manufacture -SWT China, Engine-Cummins-KTA19-G4,Alternater-Seamford HC5D. LSM672 is our load sharing module.
We purchased one new Cummins Power Command Control 3201 model Gen set for replace one of our existing generator.This is completely different control system.Please anyone can explain if it possible or any solution Cummins PCC 3201 can connect with our existing load sharing system(LSM 672)
Thank you so kindly
Kumar
Re: Load Sharing
09/11/2010 1:44 AM
about two (2) days ago we've been visited by one of our trusted suppliers and were given an orientation\seminar of the power managing device called EasyGen..i forgot what was the name of the manufacturer...in the said event, one question was raised by our fellow worker here regarding the compatibility of the EasyGen power manager and our existing system...the answer was "No" we need another set of the said device to have an auto-load sharing...my guess was because of the CAN bus sytem of the two devices were different...
Re: Load Sharing
09/11/2010 8:09 AM
Hi,
first i would like you to the answer the following question, what led you into buying a different controller?
since all your 4 generators are identical the paralleling of outputs is easier.You need to identify what parameters your LSM control monitors and what parameters your PCC monitors, list them on are table and note the similarities i.e. LSM input1 is L1 voltage while PCC input 6 is L1 voltage. Marry the corresponding parameters and your system is good to go.
