Previous in Forum: FRP Coating on SS 304 Tanks to Prevent Acidic Reaction   Next in Forum: Line Sizing
Tank Sizing
09/11/2010 7:42 AM
What should be the day tank size if i have consumption of 50 kg/hr on process side?
On this basis how should i design storage tank?
Be not afraid of growing slowly, Be afraid only of standing still.
Re: Tank sizing
09/11/2010 7:57 AM
Do you know what a day tank is?
Re: Tank sizing
09/11/2010 7:58 AM
day tank means it supplies contineously fluid to the process or consumer
Re: Tank sizing
09/11/2010 8:03 AM
do u mean it supplies for a day
Re: Tank sizing
09/11/2010 11:43 AM
Yes a day and not all days are the same ..... in this part of the world, today is a holiday, don't expect to run a full crew, or that your suppliers will. hope this clears up your confusion.
klearzen
Re: Tank Sizing
09/11/2010 6:37 PM
This and the two adjacent threads are rather vague, and might better have been combined to depict the entire system.
I would consider using a float valve (also called a "trough valve," like a toilet float) to feed the emulsion into the roller tank. There will be some turbulence at the infeed point, but you could put a baffle in the tank so that the infeed is into one compartment while the roller is in a quiescent section. [?] This should give a uniform coating of emulsion onto the roller.
Re: Tank Sizing
09/12/2010 3:32 PM
This sounds like a really simple math question, am I missing something here!
Do you know how long the plant production day is so you can multiply this time by your consumption value to estimate the minimum size your day tank needs to be? Take into account same-day production overtime and a reserve capacity safety factor and that should be all you need.
If you cannot do the above sizing you really should get someone more qualified to do the design and purchase/build/install for you.
Register to Reply 6 comments
bhalchandra (2); jack of all trades (1); klearzen (1); lyn (1); Tornado (1)
