Previous in Forum: Suitable and Optimum Process and Position to Weld SS316L to SS316L or SS304L   Next in Forum: High Gloss Paint for Plastic Part
Engineering Fields - Piping Design Engineering - New Member
PWHT - Stainless Steel
09/14/2010 12:34 AM
Whether PWHT comes as a requirement or not in any grade of Stainless Steel irrespective of the service specially with regard to L grade? Also in case of which service PWHT comes in Stainless Steel & for which grade if any?
At least I have not seen any case. Thanx in advance
annu
Re: PWHT - Stainless Steel
09/16/2010 5:45 AM
Generally PWHT is not required in Austenitic stainless steel, but it is required in Martensitic and ferritic stainless steel n normally depends on base metal thickness and the base metal.
09/23/2010 1:51 AM
Brother, may i know which code involve this. As so far i haven't face this issue be4. Don't all the stainless steel under P8 in ASME??
Register to Reply 2 comments
