Previous in Forum: TAYLOR-DUNN MB-248-10EF Manual   Next in Forum: PWHT - Stainless Steel
Suitable and Optimum Process and Position to Weld SS316L to SS316L or SS304L
09/13/2010 10:31 PM
the conditions are 1.5-4barg at P for Steam in jacket conveyor, 25<x<100 degree C for product, monoglyceride (palm oil product), Pipel classification- S216F/G. Based on the given information. i want to know wht generally speaking, suitable and optimum process and position to weld SS316L to SS316L or SS304L to avoid any steam and monoglyceride leakge. Both jacketed line and the product line are SS316L this weldment occurs at a place , where a sampling valves (Possible Material : 304, 304L, 316, 316L) installed to this main pipe(jacketed and product pipe).
tx
Re: Suitable and Optimum Process and Position to Weld SS316L to SS316L or SS304L
09/14/2010 2:56 AM
Is this for a food-based product?
09/17/2010 12:33 AM
is a food based product
Good Answers: 67
09/15/2010 6:07 AM
All the four grades of SS i.e. 304,304L,316 & 316L can be successfully welded to each other by TIG welding using argon as shield gas. Go for radiography test, if more perfection is needed.
09/15/2010 11:32 AM
Hello everybody:
westdeap12, read this document, it can be of some help for you.
http://www.eng-tips.com/viewthread.cfm?qid=165169&page=1
Good luck!
Register to Reply 4 comments
ELEMAN (1); pritam (1); PWSlack (1); westdeap12 (1)
