Hi all:
Anyone used to have problem with Electric forklift? I need your suggestion by pointing out what points to be checked during one situation as following:
1. The newly bought forklift (not over one year).
2. The low-battery lamp turns on after several hours of working. Yes, it is much shorter than the recommended hours.
3. The charger is working well. After a working day, the forklift is recharged for the next day working.
4. We have checked the battery voltage and it is a bit higher than requirement. It is Ok.
How is the procedure should be carried for this situation? Or what is the symptom it possibly be? Note: Contact to supplier is a must but it would be the last solution.
Thank you,
Hien
