Previous in Forum: Converting 1993 Honda to CNG Vehicle   Next in Forum: One and One....
25 comments
Rust in Gas Tank
09/14/2010 1:10 AM
What's the best method of cleaning out a rusty gas tank?
Re: Rust in tank
09/14/2010 3:13 AM
  • Send quotation.
  • Receive purchase order.
  • Apply forced ventilation.
  • Atmosphere test.
  • Receive Permit-to-Work.
  • Receive Confined Spaces Entry Permit.
  • Enter tank.
  • Use high-pressure water jetting.
  • Drain waste water to appropriate place.
  • Exit tank.
  • Close permits.
  • Bugger off.
  • Send invoice.
  • Receive cheque.
  • Bank cheque.
Reply Off Topic (Score 6)
Re: Rust in tank
09/14/2010 4:48 AM
Some automotive radiator shops will cook out and repair a gas tank. Check around your area , they may be able to help you out. The only problem is you have to remove the tank yourself or have someone do it for you.
h
Good Answers: 60
Re: Rust in tank
09/14/2010 4:51 AM
Trinitro toulene hehehehe
ps what sort of tank
car
lorry
bus
above ground storage
under ground storage
fuel tanker
what ?
Re: Rust in tank
09/14/2010 7:18 AM
Re: Rust in Gas Tank
09/14/2010 8:02 AM
I just recently cleaned the rust out of a motorcycle gas tank this way. This tank is small enough to handle and rotate by hand.
Put a small pile of clean gravel in the tank. Rotate and shake the tank until your arms go limp. Do this daily for a week. You will have a spotless gas tank or severe muscle cramps. Pour out junk.
Now pour in a bottle of jellied rust remover (navel jelly is one brand) which is available at auto parts stores. Tilt and rotate tank until inside is coated. One hour later (per instructions) thoroughly rinse with water. Blow vacuum cleaner exhaust thru tank until completely dry.
Everything I know about opera I learned from Bugs Bunny
Reply Good Answer (Score 4)
Good Answers: 123
09/14/2010 8:36 AM
When I was younger, they sold machines that were supposed to help people loose weight. Sort of a motor mounted horizontally at waist level, with a wheel on either side. Attached off center to the wheels was a mount for a belt that went around your part of your body that needed reduction. So as the motor rotated, the belt would try to twist one's butt side to side.
Your description of cleaning the gas tank would have been so much easier if one was using one of these machines. Just a thought.
Bob
09/14/2010 9:36 AM
I've never seen one of those in person, butt is that the exercise machine that was a mainstay in 1960/70 sitcom gags?
Good Answers: 123
09/14/2010 9:43 AM
Yes it was.
Bob
Good Answers: 42
09/14/2010 9:33 AM
External or internal?
Nature is so graceful and naked. Human possession is ridiculous.
Good Answers: 179
09/14/2010 10:41 AM
My experience has been that if there is a rusty interior you're far better off in the long run with replacing the gas tank.
This is because whatever you do to treat the tank to remove the rust, it (the rust) will most likely keep coming back over and over again, causing a whole host of problems down the road into the future such as: clogged fuel filter, failed pickup pump, clogged fuel line, and clogged carb venturi jets.
Been there and have done it several times over the years.
It's better to play it safe then sorry....
Good Answers: 123
09/14/2010 11:56 AM
Eastwood corp sells a product that is designed exactly for sealing gas tanks in older vehicles that are not available any more.
If I was the one that had to go through the bother of removing rust from the bottom of my gas tank, I would be damn certain that I did not let it develop water in it again.
Bob
Good Answers: 179
09/14/2010 1:05 PM
Bob, is that Eastwood product similar to their Rust Encapsulating product(s)? I haven't used it yet, but have contemplated buying it in the near future.
You're correct to want to make sure that the tank is properly sealed and corrosion-free during a rehab, especially if the tank is not available anymore aftermarket or OEM (ie, irreplaceable).
I've used their rust removers (gel and liquid), similar to Evap-o-Rust, and they work great! I have nothing but praise for all three products!
Good Answers: 123
09/14/2010 1:12 PM
Not exactly. http://www.eastwood.com/ew-gas-tank-sealer-kits-for-cars.html
This is the product I was thinking of.
Bob
Good Answers: 196
09/15/2010 1:42 AM
If you're in the USA where chemicals and paints can be shipped by common carriers the Eastwood product is probably good. Their products have a pretty good reputation for quality.
When I did the gas tank in my old V-8 Ford 15 years ago I used a Por-15 gas tank treatment kit.
http://www.por15.com/FUEL-TANK-REPAIR-KIT/productinfo/FTRK/
Worked real nice. The sealer paint part of the kit is a pretty bullet proof air curing coating (I think it's the humdity in the air that does the job). So I can heartily recommend that product. But note once you open the can you have to use it pretty soon. So follow the instructions carefully.
Ed Weldon
Good Answers: 123
09/15/2010 11:11 PM
I have wondered about Por-15 for years. Thanks for the advice.
Bob
Good Answers: 22
09/14/2010 11:38 PM
Molasses as a 10% solution in water (1 part Molasses:9 parts water) will deactivate rust as long as its not too scaly.
I would suggest DaveB's solution with the gravel (can also use old nuts & bolts in lieu of gravel) to remove the scale.
Then fill with above solution for a day or so.
Do not use on cast iron, as I'm told is ruins cast iron parts, but steel is ok.
You can buy Molasses at any produce store. Often used as animal food supplement. Its the crude form of Treacle.
09/15/2010 6:24 AM
Are you talking about a petrol/ diesel (as in the US terms "gas station" and "I am going to gas in my car") tank or a gas (the state of matter distinguished from the solid and liquid states) tank?
If the tank is rusty then perhaps the best solution (depending on the application and internal pressure of course) would be to replace it.
"New and stirring things are belittled because if they are not belittled, the humiliating question arises, 'Why then are you not taking part in them?' " - H. G. Wells
09/15/2010 7:31 AM
I did the sand/gravel thing 10 years ago on an old Studebaker Truck tank.
The used "Bill Hirsh" brand Tank Sealer.... but any brand will do.
Haven't had a problem since....
Now I'm retrofitting the brakes to Silicone fluid... and dual pot master cylinder....
09/15/2010 7:38 AM
Explosives!
Good Answers: 109
09/15/2010 8:48 AM
If it is a small tank DaveB #5 is a good remedy. If it is a larger tank, you should replace it with new tank or Renu. There is a network of Renu dealers in North America. I have a friend in the area who operates such a business and says it is great. I have not used his Renu service but they are reliable mechanics who do work for me as required. FYI
If it is a very large UST then you will be required to replace it as per regulations. UST=underground storage tank. The environmental cleanup of a leaking UST will exceed the replacement costs.
09/15/2010 9:01 AM
I've always used a chain placed inside the tank instead of gravel. Shake and turn like crazy. After cleaning the tank out, place it in an oven ( wife should love helping you with your car project ) and heat to about 480F. Remove from the oven and pour in about a quart of Polyethylene plastic pellets. Slowly turn the tank and allow the pellets to melt into the wall of the tank. Its like rotational molding at home. It's a very permanent fix that even seals seams.
Ok someone in your area may offer this service already and you will be able to stay out of the kitchen, keeping the peace & harmony in the home.
If I hear hoofbeats, why don't I ever think a Zebra might be around?
Good Answers: 123
09/15/2010 11:09 PM
Hello. Is this Domino's? I wonder if I could bake my gas tank in your oven after work today? Hello? Hello? I wonder if it was something I said?
Bob
09/16/2010 2:56 AM
Por-15
09/16/2010 10:51 PM
standard method is to vat/boil the tank, which is a job well suited to today's radiator shops. We have to clean them before shipping and they have to be tested for HC's before the shippers will accept them. My local radiator shop has done several for me and we have never had one rejected for shipment due to the presents of HC's after vatting/boiling them out.
09/17/2010 10:48 AM
Do you lose the exterior paint job when you do that? I have a neglected tank I want to clean but I don't want to lose the factory paint job.
Reply to Forum Thread 25 comments
AGuest (1); Anonymous Poster (5); bob c (6); Brave Sir Robin (1); CaptMoosie (2); DaveB (2); Ed Weldon (1); Engineering Superman (1); kevinm (1); lyn (1); OldTechNewToys (1); peterg7lyq (1); s.udhayamarthandan (1); Sparkchaser (1)
