Previous in Forum: Direction of Rotation   Next in Forum: Grounding of Generators
Type of Motor Enclosure
09/14/2010 5:01 AM
Please guide me the difference between TEFC, TETV and CACA motor enclosure (more than 500 KW).
Also guide me about selection criteria for above three.
Re: Type of motor enclosure
09/14/2010 6:48 AM
From Reliance website:
MOTOR ENCLOSURES
Reliance offers the industry's widest selection of motor/generator enclosures to meet specific operating needs.
ODG - Open Drip-Proof, Guarded
ODG-FV - Open Drip-Proof, Force Ventilated
ODG-SV - Open Drip-Proof, Separately Ventilated
ODP - Open Drip-Proof
HP - Vertical P-Base, Normal Thrust
LP - Vertical P-base, Medium Thrust, Extended Thrust
Prot. - Protected
TEAO - Totally-Enclosed, Air-Over
TEBC - Totally-Enclosed, Blower-Cooled
TECACA - Totally-Enclosed, Closed Circuit,, Air to Air
TEDC-A/A - Totally-Enclosed, Dual Cooled, Air to Air
TEDC-A/W - Totally-Enclosed, Dual Cooled, Air to Water
TEFC - Totally-Enclosed, Fan-Cooled
TENV - Totally-Enclosed Non-Ventilated
TETC - Totally-Enclosed, Tube Cooled
TEWAC - Totally-Enclosed, Water/Air Cooled
TEXP - Totally-Enclosed, Explosion-Proof
IP-22 - Open Drip-Proof
IP-44 - Totally-Enclosed
IP-54 - Splash Proof
IP-55 - Washdown
WPI - Weather Protected, Type I
WPII - Weather Protected Type II
XE - Premium Efficient
XL - Extra Life
XP - Explosion-Proof
XT - Extra Tough
and CACA: closed air circuit air cooled
You should really do some research on your own. We can't inject you with knowledge.
05/10/2012 12:21 PM
Dear Mr. Lyn,
I want to supplement to your list.
SPDP - SCREEN PROTECTED and DRIP PROOF.
Thanks,
DHAYANANDHAN.S
Good Answers: 181
09/14/2010 6:56 AM
Google it!
You know the criteria you've got to match, we don't!
09/14/2010 7:04 AM
For every one you admonish to do their own work, ten more will come and ask you to make them intelligent.
Good Answers: 181
09/14/2010 8:30 AM
Do we know the criteria that the motor is required to meet?
The simple answer is no, we don't!
Re: Type of Motor Enclosure
09/14/2010 7:49 AM
well , I can only explain for TEFC and CACA, which can be used for one type of motor
TEFC- totally enclosed fan cooled, means for a type of motor which has a difference between inner and outer air for cooling. The motor lamination is totally closed in the stator housing and it is cooled by a flow of inner air (with rotating inner fans), and the heat exchange is through the pipes or ribs (or through water exchanger on the top). Pipes can be around the stator housing or in the heat exchanger on the top of the motor.
CACA- cooled air, cooled air - lamination is cooled with inner air (primary air), and secundary air is going through the pipes ( heat exchanger).
so, one type can be TEFC CACA....
TETV, I haven't heard about this one but totally enclosed it is....
Vitas
Register to Reply 6 comments
dhayanandhan (1); lyn (2); TonyS (2); Vitas (1)
