Previous in Forum: 132kw 3-Phase Induction Blower Motor   Next in Forum: rely
Earth brush - benefits
09/14/2010 12:37 PM
Why earth brush is connected to a 3-phase induction motor?
Re: Earth brush - benefits
09/14/2010 1:11 PM
Is it a shaft earthing brush? If there is a possibility of significant shaft voltage then it is preferable to ground the shaft with a brush. Otherwise, the bearings will be under stress and this may lead to bearing failure. Many a times ,for larger installations (> 2 MVA)we also ask the user to monitor the current through the brush to detect incipient abnormalities.
Better not count the cent if the risk is many many dollars.
09/14/2010 2:18 PM
yes it is shaft earthing brush
Good Answers: 804
09/14/2010 1:12 PM
Do a search on the term "AC motor shaft current" and you will find papers and references to a phenomenon that was virtually unknown before the advent of inverter drives. A shaft grounding brush is one way to provide a safe path for these stray currents, as opposed to flowing across the bearings and bearing races where they cause damage.
Good Answers: 181
09/15/2010 4:26 AM
There is another method of protecting the bearings, used mainly on older mill type motors with pedestal bearings. Both bearings are insulated from earth, but then one bearing has an earth strap to it to ground the shaft. In this way circulating eddy currents can't pass through the bearings. It has one major down side and this happened to me, a production worker propped a crow bar against the insulated bearing pedestal and left it there for several days. The bearings didn't sound very happy when I got to it!
Register to Reply 4 comments
Jans (1); JRaef (1); salahuddin zia (1); TonyS (1)
