Dear Friends,
We are having 200TPH pulverised coal fired boilers. Our Primary air circuit takes hot air from Sec air duct [ after RAPH] and feeds to the Coal Puverisers. Primary circuit parameters are P.A fan I/L = 250mmwc, P.A.Fan O/L = 900mmwc. Hot air temp= 320deg [ both].
We are facing problems of hot air leakages in P.A circuit through a) Expansion bellows [metallic], b) Slide gate seals, c) P.A Fan seal side, d) ATM damper shaft gland.
My question is 1) What can be done to avoid buckling of slide gate? Can a single plate welded near the end of gate prevent buckling OR will it do any damage to SS-316L gate?
