Previous in Forum: Slide Gates in Primary Air Circuits   Next in Forum: Maximum Vibration
mechanical
09/15/2010 3:24 AM
where gate valve and ball valve is used? what will happen its interchanged?
Pathfinder Tags: valves
Re: mechanical
09/15/2010 5:18 AM
A ball valve is handy for situations where an on/off is required to the flow at frequent intervals and the materials of construction need to be something other than brass/bronze/cast iron.
Ball valves get unwieldy and rather heavy as the pipe diameter increases.
For the fullest answer, refer to the end Client's piping specifications.
Re: mechanical
09/15/2010 8:05 AM
Basically the Piping Specification of the End User should define these requirement as the end user is the operator.
Normal practice is that selection is based not on fixed universal rules but depends on service conditons, line size / class, process / operability requirements etc.
In Common practice: Smaller sizes 1/2" upto 20"Ø Ball Valves are desired or better suited, and over the 20"Ø Gate vavles are applicable.
Register to Reply 2 comments
