Previous in Forum: Electric Motor Drying Equipment.   Next in Forum: Short Circuit Test
Contactor Coil Burnt
09/15/2010 8:41 AM
Dear Sir
We have one York make chiller at our factory
Starter of this chiller is Star/Delta starter ,we are facing problem of delta coil burnt frequently (Coil volt=110VAC)
Cheked coil voltage found OK
Can you please suggest any remedy to this problem
India - Member - New Member
Good Answers: 164
Re: Contactor coil burnt
09/15/2010 9:50 AM
Contactor coil can burnout due to one or more of these reasons:
  • Low or High voltage
  • Full closing of magnet faces prevented by something
  • Shorted turns
  • End-turn insulation failure
  • Impulse voltage
  • High ambient
  • Too frequent starts
  • Control transformer inadequate, resulting in contactor failing to pick up
If you give more details of your setup,it will help.
Good Answers: 170
Re: Contactor Coil Burnt
09/15/2010 10:04 AM
Is it open transition or closed transition?
Good Answers: 181
09/15/2010 10:41 AM
Is there a mechanical interlock between the star and delta contactors. Their the favourite for going wrong.
09/15/2010 11:43 AM
Give more nameplate details perhaps we can fix the problem.
India - Member - design engineer Engineering Fields - Electrical Engineering - New Member United Arab Emirates - Member - New Member
09/16/2010 3:05 AM
specify all contactor details, olr, mccb details, motor name plate details.......may be the contactor rating s not proper?
for a little info on star delta starters refer these links
http://cr4.globalspec.com/thread/59853/Star-Delta-Motor-Starters
http://samplecode.rockwellautomation.com/idc/groups/literature/documents/wp/150-wp004_-en-p.pdf
shamith gambhir, electrical engineer
09/16/2010 9:52 AM
Dear Sir,
To the comments given by Mr.Sridhar, you can check up the shading
copper ring of the contactor for any breakage or partial obstruction while
closing.
Manroop. Chennai.
Good Answers: 164
09/16/2010 10:33 AM
Ah yes manroop, good point. i missed that, thanks.
However, a broken shading ring would cause a godawful noise, OP you can tell us.
My own vote would be too small a control transformer, since it is 110V. Main and star contactors would pickup together usually, and the inrush current would be too high, voltage would sag, contactors may "pump" (drop off due to low voltage, pickup again with a staccato action), overheat and burn.
Anyway, in the absence of more data, nothing further seems possible.
Anonymous Poster (1); electricalexpert65 (1); kvsridhar (2); manroop (1); SHAMITHGAMBHIR1 (1); TonyS (1)
