After researching some of the commercially available load banks out there, I am thinking about building my own from readily available components and parts. My problem is finding loads large enough. Here are my thoughts:
DC Load Bank:
- Must have the ability to test 24V, 48V, and 130V DC loads up to 200A.
- Purely resistive loads are required. No motor starts, or inductive loads need apply.
- Must have the ability to step the load up from 100W to 5,000W in increments of 200-500W I was thinking.
- Must be compact enough to fit in a lab setting. It would be really nice if it was rack mountable.
- I am not interested in metering the load, as I have enough meters on the EUT to satisfy my data needs.
AC Load Bank:
- Must have the ability to test 100VAC-240VAC.
- Purely resistive in design.
- Stepping ability up to 3000W.
These are purely brainstormed thoughts, as I am trying to piece together the components. I have already built a small AC load bank with incandescent lights connected in parallel. The downside to this is the high heat output of the lights in a small lab setting, and the intensified light of course. I am limited to 1200W with my small load bank, but I have increased that with the use of a variable heat gun and hair dryer. I have also entertained the thought of infrared heat cones like those used in reptile terrariums. The largest of these is 250W though, and I would need a ventilation system to evacuate the generated heat discharge.
