Previous in Forum: Two Indoor Stock Tanks - One Filter   Next in Forum: Insulation Resistivity of Cable
Polar Mohr 71
09/16/2010 9:36 PM
I am working on a polar mohr 71
The center PCB has a bad (1watt?) resistor that I can't read the value on.
It is in the lower left corner in series with a 25uf 630v cap that is also bad.
Pathfinder Tags: polar mohr
Re: Polar Mohr 71
09/17/2010 3:19 AM
Start by unsoldering them and measuring them. Then replace them.
Re: Polar Mohr 71
09/17/2010 5:38 AM
Good advice but the resistor exploded and burnt the discription on the pcb :(
Good Answers: 181
Re: Polar Mohr 71
09/17/2010 6:14 AM
Contact the manufacturer for a circuit diagram or service manual.
The under lying problem is what caused it to "fry" in the first place?
Good Answers: 12
Re: Polar Mohr 71
09/18/2010 5:46 AM
At a maximum voltage of 630v the resister would have to be 400k or greater if the voltage can be applied continuously, to dissipate less than 1 watt. You could guess at double that? It would sure help if you knew what the circuit does. Could it be sensing a drive clutch voltage?
Good Answers: 151
Re: Polar Mohr 71
09/18/2010 6:57 PM
I really don't want to get into this discussion, but I have been fighting a Polar Mohr for the last three years. Mechanically, they are great machines, but their electrical control system is the worst, most obscure that I have ever worked with. To make it worse, their Distributer in the US refuses to provide any technical support. Why are you trying to fix a bad PCB, why can"t you get a replacement from Polar Mohr?
My solution is either dump the machine, or rip out the entire control system and replace it with a modern press control. After all, it is just a mechanical press, no different than a punch press.
Re: Polar Mohr 71
09/20/2010 10:56 AM
The company I work for has many parts for these old polars. We may have what you need in our parts dept. Contact them at parts@absoluteprintequipment.com
Re: Polar Mohr 71
10/07/2010 6:57 PM
the board # is (polar 012188) the resistor and capacitor are in series connected across to pins of connector 70.
Register to Reply 7 comments
gringogreg (1); inlgh (1); PWSlack (1); Rebuilt (1); redirtokie (2); TonyS (1)
