For 2.2KM lengthy conveyor we have planned to install 2 x 250kw 6.6KV motor now we are thinking of changing over to LT VVFD or 6.6KV soft starter can any body suggest which one is better the intention is smooth starting of the conveyor.
I am not trying to answer this question and I understand you already have the conveyor in place. But I thought you may be interested in this new invention. A conveyor with multiple drives along the belt. http://www.innovativeconveying.com
"A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away."
Best is a subjective term. VFDs for 2 x 250kW motor in low voltage will probably be more expensive than a single 6.6kV soft starter running two motors, so from an initial cost standpoint, the SS would be best. Smoothest start? VFD without question. A VFD can accelerate the conveyor at any speed stretched out over any amount of time. But having two VFDs allows you the flexibility to ensure that the motors are equally sharing the load, soft starters cannot do that. A 2.2kM conveyor belt will act like a rubber band then accelerating, so VFDs allow compensation where soft starters cannot. VFDs can also allow for some breaking capacity if any part of the conveyor goes down hill.
