Previous in Forum: Dissimilar Welding of Austenitic Stainless Steel to Carbon Steel   Next in Forum: Electrical Project
Star Delta
09/19/2010 8:40 AM
can I operate a 340 KW motor in star delta.If no which is suitable method and give me the starting current of each method
Re: star delta
09/19/2010 10:45 AM
Sure you can wire a motor in any configuration that you know, using any voltages available. It's your motor and electric bill. But if you wish the motor to last the manufacturer's expected lifetime, then you should refer to the manufacturer's documentation for your motor. If the motor's name plate doesn't provide a specific model and manufacturer identification, then you should investigate your system documentation. If this doesn't help then you will have to have an on site engineer evaluate your operation to reverse engineer the motor requirements.
Re: Star Delta
09/20/2010 12:25 PM
This also depends on whether enough leads have been brought out of the motor to enable it to be connected both ways (Y-Δ).
Register to Reply 2 comments
