Redoing two rooms on my second story of my house. Ceiling is the roof. There was celulose insulation previously with plaster and lathe walls. I'm not fond of celulose and wondering what will do a good job of insulating. Walls/roof are the usual 2x4s common in older construction i.e. house was made around 1918. Completely rebuilding the roof is not feasible due to funds.
I will factor in appropriate ventilation also. Currently have the non-powered turbine vent.
Do I go with styroform boards, unfaced fiberglass or fiberglass with the reflective aluminum foil as a barrier?
Thx.
