Previous in Forum: jaw crusher(9.20)   Next in Forum: Jt Venture/Technology Transfer Partner required for Power Transformers in India
Good Answers: 49
High Efficiency CoGen System
09/21/2010 11:26 AM
Lighthouse Utility Solutions, Inc. of Cincinnati, OH, USA (513-708-4420) has developed a new version of the "good, old" CoGeneration package that operates at an annual thermal efficiency of 99%. During warm weather, it operates at over 100% (based on fuel input) because the leaving exhaust will be cooler than the entering combustion air. Impressive since "current" CoGeneration systems typically operate at 65-70% thermal efficiency (60% is the minimum acceptable for Federal grants).
Each MODULAR unit produces 300 kVA of 480 VAC, 3-phase power plus about 2-million BTUH of recoverable heat that makes a combination of high temperature hot water (can be flashed to steam at up to 150 PSIG) and hot water (up to 220F).
Because of the high thermal efficiency, the unit essentially matches or beats a normal steam boiler for thermal efficiency, so the electricity is essentially free. The unit also makes 380,000 gallons of near-potable water from the condensed exhaust.
The equipment can operate on natural or LP gas or an add-on module will vaporize liquid fuels like fuel oil. Additionally, it can also run on RENEWABLE energy inputs like landfill gas, digester methane or vaporized bio-diesel, ethanol or bio-kerosene.
Environmental benefits, beyond renewable fuel use, include 80% reduction in CO2 releases and 95% reduction in NOx, compared to "normal" electricity production and thermal system operations.
The two modules (generator and thermal recovery) are about 90 inches tall, 84 inches wide and 168 inches long. The liquid vaporizer module adds another 60 inches length to the thermal recovery unit. The units are designed to mount on 6" high concrete pads but multiple-unit modules can be installed using a structural framework.
Each standard system costs about $2500 per kVA ($748,500) and qualifies for the current Federal Renewable Energy Grants of 10% of the TOTAL installed cost. Several states also offer some form of tax relief or rebates for further final cost reduction. It typically has a payback of about 2 years or less.
ADDITIONALLY, those systems using renewable bio-mass fuels also qualify for the Federal Renewable Electricity Production Tax Credit that is $0.022 per kWh (that is $57,816 annually PER MODULE) and the credit is in place for 10 years (unused credits can be carried forward for 20 years).
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
Pathfinder Tags: Lighthouse CoGen
Re: High Efficiency CoGen System
09/25/2010 12:38 AM
Very impressive. Now down scale it so I can put it in my back yard for power, space and water heating and irrigating our garden. Oh - and make it for less than $10,000.
If that could be accomplished I'll bet the market size and the economics of scaled production would make it the more profitable of the two units.
Gavilan
Good Answers: 49
09/25/2010 2:01 AM
We are working on that as well.
We have redesigned the "good old" steam engine so it can make comparable power with less than 10% of the "normal" steam use. Because steam engines only care about the PRESSURE of the input, their output climbs as the input pressure rises.
For example- a 200,000 BTUH thermal input producing 300 PSIG steam can make about 34 horsepower or 19 kW. That same input at 900 PSIG can make 111 HP or 62 kW. Boosting the pressure to 1500 PSIG will yield 193 HP and 107 kW and 2500 PSIG will produce 353 HP or 196 kW.
Additionally, we can condense the discharge steam to reclaim nearly ALL of the net input thermal energy (80% of the gross input energy), and condense the exhaust to reclaim over 90% of the remaining 20% of the gross input energy- that is 98% of the gross thermal input reclaimed AND about 27,800 gallons of water a year (3.2 GPH). All of the models noted above can also recover 196,000 BTUH as hot water (up to 220F).
Not counting the boiler- which can run on renewable fuel- the box would be 2 feet wide, 5 feet tall and 6 feet long. The cost will be more than $10,000, but- with a high enough output and selling power to the grid, the payback is about 2 years.
We are building the prototype for this engine now, so we will know "real" output performance within a few months.
10/30/2010 10:42 PM
Very Very Cool.
Register to Reply 3 comments
