Previous in Forum: Piping - Eccentric Reducers   Next in Forum: Boiler Efficiency-Loss Method
Difference Between RT1 and RT2
09/22/2010 7:48 AM
Can anybody make me clear what RT1 and RT2 means?
United States - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: Difference Between RT1 and RT2
09/22/2010 8:01 AM
Help us so that we can help you.
Is this a part of a formula?
Could you give us an example of it being used in a sentence?
Are these directly related to the field of mechanical engineering?
09/22/2010 8:46 AM
i mean radiography test1 and radiography test 2 ..
Good Answers: 48
09/22/2010 8:25 AM
Any relation to R2D2?
09/22/2010 8:31 AM
Radiography Test 1 and Radioghaphiy Test2 ?????
Good Answers: 29
09/22/2010 8:36 AM
Resistance total?
09/22/2010 9:34 AM
There may be two depending on what/where you have come across.
1) Less used - Radiography Certificate level 1 or level 2 (usually it is called as such) but you may rarely come across people calling themselves I am RT1.
2) In case of radiography tests- first shot is RT1. In case it failed and is repaired the post repair second shot will be called RT2 (usually with location as (RT2- EF) and so on depending on the number of repairs (and hence re-shots)
UD15
Register to Reply 6 comments
Anonymous Poster (1); Holzfeller (1); Jaxy (1); RDGRNR (1); shanii (2)
