Previous in Forum: Difference Between Felt and Belt   Next in Forum: Difference Between RT1 and RT2
Piping - Eccentric Reducers
09/22/2010 5:49 AM
Eccentric reducers are used with flat bottom at control valves, why?
Re: piping - eccentric reducers
09/22/2010 5:56 AM
There had been quite a few threads on this topic like this orr this
Use search feature on Right side with Eccentric reducer. If you don't get what you are looking for then put the question here. Else it becoomes unnecessary repetition for all.
UD15
09/22/2010 6:02 AM
After searching old threads I could find eccentric reducers topic as applied to pump suction only.
Whereas what I need is for the case of Control Valves in piping systems.
thanx
Good Answers: 97
09/22/2010 6:35 AM
Flat at the bottom - At a control valve you may want to trap any air (or lighter fluid) and expel it via an air release valve before it is introduced in the system.
This is not true in cases where the intruder fluid is heavier than the fluid to be controlled.
What is your situation ?
Investment castings, Investment castings manufacturers and suppliers in India
09/22/2010 7:26 AM
CR4 Admin: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Good Answers: 137
09/22/2010 9:01 AM
I've always used concentric reducers with control valves (even in horizontal pipes) and never had any problem. There's usually plenty of turbulence at a control valve, so any gas is entrained and carried away.
Cheers..........Codey
09/22/2010 9:28 AM
We usually use concentric reducers for the control valves and additionally at 5D distance between the valves and the reducers.
The various literatures too mention the concetric reduceres (eg emerson process cvh99
Page 114 The most commonly used fitting in control valve installations is the short-length concentric reducer.
Also you may look at the sample problems at page 117.
Eccentric reducers (bottom flat) are useful if the the equipment (and that includes the valve) encounters 2-phase flow (Gas and a liquid). If it is solid and liquid it may be otherway round. It is to ensure that the liquid does not accumulate. This may result in water hammer as the flow may alternate between liquid and gas. There may be rare cases where it would be advantageous to have eccentric reducers with top side flat.
UD15
Anonymous Poster (3); Codemaster (1); Hendrik (1); Trident (1)
You might be interested in: Piping Services, Piping Systems, Flat Belt Pulleys
