Previous in Forum: Reaction Steam Turbines   Next in Forum: Piping - Eccentric Reducers
10 comments
Difference Between Felt and Belt
09/22/2010 4:22 AM
Can anybody explain the difference between felt and belt?
Good Answers: 16
Re: Difference between felt and belt
09/22/2010 4:27 AM
Exactly one letter
09/22/2010 4:58 AM
same as between rubber and hat stand
09/22/2010 9:56 AM
Wouldn't it be closer to cat and hat?
Good Answers: 266
09/22/2010 7:03 AM
Depend on the use of the words as nouns or verbs. Both could be either. We would need context in its use.
You should ask Webster though he would have a complete explanation.
09/22/2010 7:13 AM
You should ask Webster .
Isn't he a BIG spider?
Good Answers: 266
09/23/2010 7:07 AM
Are insinuating spiders are dumm
Re: Difference Between Felt and Belt
09/22/2010 12:18 PM
The strength of the impact. Feeling something is a lot softer than belting it, which can be quite hard to withstand; it is likely to show some impact damage in response to the latter.
09/22/2010 3:37 PM
Felt
http://en.wikipedia.org/wiki/Felt
Belt
http://en.wikipedia.org/wiki/Belt
Possibly
http://en.wikipedia.org/wiki/Belt_(mechanical)
This is a very bizarre question, can you provide more information or do you want to just give me a GA for answering your question?
09/23/2010 1:15 AM
In our corrugator machine, we have a Felt (name in manual) at double facer which is used to pull up the web and run it on hot (190C) plates in order to dry the glue between two layers.
The belts (name in manual) are used to transport the dried board after cutting into required length. I think, we can say that felt is used in high temperature areas and belt is in low temperature areas.
I am open so someone can correct me.
09/23/2010 2:42 PM
It is hard to say without seeing the manual. It could be a felt belt, a belt (a typographical error), felt could be a copyrighted name of a special belt and/or material, etc.
From your description it does sound like the 'felt' is a high temperature belt (or similar) device. A visual inspection of the inside of the machine may help (after the machine has been turned off and allowed to cool of course).
Register to Reply 10 comments
dgibson (1); jack of all trades (2); ozzb (2); PWSlack (1); Signode (1); Tim in Mexico (1); user-deleted-1105 (2)
You might be interested in: Flat Belt Pulleys, V-belt Pulleys
