Previous in Forum: Electrical Question - Maximum Load?   Next in Forum: Difference Between VVVFD & VFD?
Logic for Damper Closing
09/23/2010 4:47 AM
I have 5 bag house each have in let and out let valve (air pressure operated).I want to close inlet & outlet of each valve one by one and keep each one closed for 5 minutes.
can you have any logic idea .Is it possible with out any electronic circuit.
Good Answers: 181
Re: logic for damper closing
09/23/2010 4:52 AM
Make it 6 minutes and use a 30 minute cam timer.
09/23/2010 6:46 AM
do u mean a timer card
Good Answers: 181
09/23/2010 7:06 AM
Look cam timer up!
I give up!
Re: Logic for Damper Closing
09/29/2010 8:11 AM
You can set up a simple PLC circuit which will energise/de-energise a solenoid to the supply valves (or pilot operated valves). Alternatively, it can all be done with pneumatics using a small capacitor bottle with a variable orifice. Depending on how you want to do it, you could sequence the pneumatics so that the second one opened after the first one closed etc. Depending on your time frame, this could be a good project for some local students or a graduate traineee, provided you get some bright, pro-active people on it. Otherwise talk to a local pneumatic equipment supplier who should be able to prepare a circuit for you and supply the necessary volume bottles, valves etc.
