The wastewater stream is loaded with foam from the food process discharge stream. This is due to the soap in the stream. The system in place for filtering includes a set of membranes which are loaded with biological bugs that clean up the stream. We have GE helping us and have installed an anti-foaming chemical but still have problems. We are new to this and have just began using out Water Reclamation system. This is basically a learn as you go system. As a tech just learning this system what are good ways to reduce the foam?
