Previous in Forum: Screen Won't Refresh in Windows XP Professional   Next in Forum: siemens micromaster 430
Gisolt #3 Bench Metal Lathe
09/24/2010 10:39 AM
could someone tell me the specks on a gisholt model #3 metal bench lathe ? are they ackward and to heavy for general agriculture maching & threading ?
Good Answers: 29
Re: gisolt #3 bench metal lathe
09/24/2010 11:40 AM
You're right! That is a big sucker. I'd say more for production than everyday repairs on your farm, but it would definately get the job done. Did you see it at an auction or something?
Good Answers: 29
09/24/2010 11:52 AM
Sorry. Here's those specs;
Specifications:
Swing over ways 28-1/2"
Swing over carriage 24"
Maximum distance chuck to turret face 54"
Cross sliding turret travel 9"
Speeds (12) 21 - 540 RPM
Feeds on carriage (16) 0.005 - 0.176
Feeds on turret (16) 0.005 - 0.176
Motor 30 HP, 1760 RPM
Power requirements 220 / 440 volts
3 phase, 60 cycle
74 / 37 amps
Coolant pump 1/2 HP
Oil capacity, headstock 12 gallons
Oil capacity, travel box 1 gallon
Oil capacity, aprons 1/2 gallon
Approximate dimensions 194" x 86" x 63" high
Features:
21" 3-jaw chuck
Coolant pump
Good Answers: 151
09/24/2010 8:26 PM
OMG I operated one of these In my distant youth. They are classed as a turret lathe and were the primary machines for mass production of big cylindrical parts before the advent of CNC lathes. They are defiantly not recommended for a one time only job. Look at the power requirements. The tooling and set up time will kill you.
