Previous in Forum: Fiberglass and Plastic Molding   Next in Forum: Determining Battery Life
Wanted: Solenoid Valve
03/11/2007 3:31 AM
I am looking for solenoid valve with the following specifications:
- Nominal pressure 100 bar (1450 p.s.i).
- 2 ways 3/8 inch.
- 220 v - 50 hz .
- tow models (Normal open & normal close).
- Application: - working with water piston pump for misting , and cleaning machines.
Thank you for your fast cooperation
Best Regard
Eng. Essam Kamel
Executive Manager
Re: Wanted: Solenoid Valve
03/11/2007 11:52 PM
try to check burket websit.
03/12/2007 3:53 AM
Dear Mr. Kamel,
Can u please give the Temp , Pressure and Flow rate too.
Is the Port size 3/8"..
Please send ur details on tykon@vsnl.net.
We are Services providers in the field of Instrumentation and can provide u economic solution on Foxboro & Emerson Instruments.
Rgds
Prakaash
09822307430
03/12/2007 3:58 PM
Dear Mr. brakaash
Can u please give the Temp (water temp. maxi 30 c)
Pressure (maxi 1200 psi)
Flow rate (maxi 15 litre/min)
Is the Port size 3/8"..(yes)
best regard
Essam kamel
FRANCE COOL CO.
6 Dr. Zaky Hassan St.
Nasr City - Cairo - EGYPT
Code postal 11371
Tel : ++ (20) 2 4022198
Fax: : ++ (20) 2 4055013
Mob: ++ (20) 12 3606724
francecool@link.net
www.francecool-eg.com
03/12/2007 5:11 AM
I would be surprised if you can find a direct acting sov for this misting system, I would be looking at a motor operated ball valve. Most direct operating sovs' at this size will have a maximum rating of about 7-10 bar dp.
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
03/12/2007 9:24 AM
GlobalSpec lets you search for solenoid valves by specification. First, choose this link. Next, in the Advanced Search box on the left-hand side of the page, choose Valve Type. In the box that displays, choose the Solenoid Valves check box. You can then use the links in Advanced Search to narrow your selection.
Hope this helps.
03/14/2007 2:27 PM
In the U.S check ASCO.
03/16/2007 10:25 PM
Dear sir
We are a chinese machinery exporter. Maybe we can cooperate.Please contact with us .henryzhang1@hotmail.com
