Previous in Forum: Pool Pump Motor: Any Creative Alternative Uses?   Next in Forum: Cp/Cv Ratio
8 comments
Engine Cylinder Temperature and Pressure after Compression
09/27/2010 12:07 AM
in a typical diesel engine cylinder, what is the usual temperature and pressure of air before and after it is compressed ? how much of diesel fuel is supplied into the cylinder ? what is the temperature and pressure after combustion ??
Re: engine cylinder
09/27/2010 12:15 AM
in a typical diesel engine cylinder, what is the usual temperature and pressure of air before and after it is compressed ? Ambient and atmospheric.
how much of diesel fuel is supplied into the cylinder ? Just enough. what is the temperature and pressure after combustion ?? How soon after combustion?
Rule #75.
Good Answers: 183
Re: engine cylinder
09/27/2010 8:36 AM
You answer only half of question: pressure after compression ?
Re: engine cylinder
09/27/2010 9:50 AM
"...pressure after compression "
Three minutes after compression it is atmospheric pressure.
Good Answers: 183
Re: engine cylinder
09/27/2010 2:45 PM
Nice joke !
Re: engine cylinder
09/27/2010 3:56 PM
About 120PSI after compression. About 500PSI after ignition, during the power stroke.
Don't quote me on those figures.
Good Answers: 183
Re: engine cylinder
09/28/2010 9:48 AM
I would not give a value because of many parameters involved:
"it is the pressure at which the compressed air reaches the self ignition temperature of diesel oil".
In a engine cylinder air suffers a polytropic compression with an exponent depending on the intensity of heat transfer from air to cylinder wall, ratio stroke/d, rpm,....
For diesel oil the self ignition temperature is ≈483K, incoming air if no supercharger or pre-heater are present has about (standard value) 293 to 298 K.
The exponent varies between 1.2 and 1.4 (adiabatic). It is quite difficult if not impossible to give more than an order of magnitude since the ratio p2/p1 varies for above values between 20 and 5.8.
Re: engine cylinder
09/28/2010 10:22 AM
I think the numbers I remembered are for a gasoline engine anyway.
Re: engine cylinder
09/28/2010 10:28 AM
I agree... 120PSI ≈ 8.5:1 compression ratio, +/-, about right for a gasoline engine. I believe diesel engines run at about 20:1.
CR4 rule #75 in full force and effect.
Doorman (2); lyn (3); nick name (3)
