Previous in Forum: Can Current be Applied to Potassium Hydroxide to Create Heat?   Next in Forum: IGC (Integranular Corrosion) Test
Transformer Varnish Removal
09/27/2010 8:50 AM
Hi all
What type of chemical can be used to remove transformer varnish from a transformer ?
Thanks for help.
Re: Transformer Varnish Removal
10/03/2010 6:28 AM
To quickly answer your question: Varnish remover. *** What part of the transformer do you want cleaned of varnish? The core? the windings? The paper insulation? The varnish covers all of the parts except the contacts or exposed wire ends. The winding wire is insulated with a varnish. If this insulation is removed, your transformer will short out and could cause a fire or electrocute someone. Is it a large transformer? What kind? Does it handle a lot of power? Why do you want the varnish removed. If you remove some varnish you will remove it from all parts in that area. if you want to use the wire it will have no electrical insulation. Varnish removers can be very dangerous, they are corrosive, flammable, harmful, poisonous or any combination of all these hazards. *** Take great care. Do whatever you do carefully and safely. It's no fun if you injure yourself or someone else.
10/24/2010 5:57 AM
i m having a varnish machine in my plant used to varnish the armature but many times the varnish coagulates on the fixtures and it takes a great deal of time to remove it from the fixture do have a chemical to remove it without the having an adverse effect to the fixture. fixture is made of iron. i also have the three step varnish drying system 1. preheating 2. gelling 3. curing. each having the temp of 180 degree centigrade. pl. suggest me the chemical to remove the varnish from fixture.
