Previous in Forum: ISO-R831   Next in Forum: Regulation of Vacuum on Liquid Ring Pumps
10 comments
Static Pressure Is Lower Than Vapor Pressure.
09/28/2010 4:48 AM
In actual (practically) term what does it mean of below phrase in fluid mechanics :
" Static pressure lower than vapor pressure at inlet of a pipe in fluid circuit (local static pressure= -0,9044 MPa) " Here fluid is industrial water @ 21 deg. cel.
This is the result (warning) of "Fathom -AFT" upon connecting two infinite source of reservoir through a 24 inch pipe having 2 m differential head (liquid EL. in one tank open to atmosphere is 310.00 m & another tank fluid EL. is 308.00 also open to atmosphere).
In practice what will happen ? When the same reservoir is connected upto 3 inch pipe there is no warning and above 3 inch for all pipes it shows the same warning.
Re: Static Pressure Is Lower Than Vapor Pressure.
09/28/2010 9:51 AM
As I understand-
The water flowing through the pipeline will have the following condition '
pressure at inlet = (outlet pressure - pressure drop in the pipe due to flow) ie
Pin = Pout - δp
As you reduce the pipe size the δp increases and that means that the Pin reduces for the same Pout
In your case if we assume that the Pout is 1 bar, the Pin is going below the water vapour pressure at the pipe inlet (and may be a bit inside too) which would result in cavitation.
UD15
Good Answers: 137
09/28/2010 4:02 PM
There's something wrong here. -0.9044 MPa = -9.044 bar. You can't have a static pressure below (approx) -1 barg (= 0 bara).
Cheers......Codey
09/28/2010 9:31 PM
This is puzzling. If the tanks are both open to atmospheric pressure, I don't see how one could get a local pressure of -0,9044 MPa. (Maybe -0,9044 kPa, but even then I don't think it's below the vapor pressure of 21°C water. But I don't usually work in SI, so I might be missing something.)
Good Answers: 137
09/29/2010 5:57 AM
Vapour pressure of water at 21°C is about 25 mbar = 2.5 kPa. But that's absolute pressure, of course, and positive. OP needs to explain the problem a lot better if we're to help him.
Cheers..........Codey
09/29/2010 2:58 AM
Vapour pressure of water at 210C is about 0.025 bar. (1-0.025 = 0.975)
BTW: The pressure of course will be below atmosphere in the inlet of the pipe even if both the tanks are open to atmosphere (refer bernoulli's principle) and can be calculated easily by calculating the heads.
For this one must know the flow and that is calculate-able since we know the head (2 mt) and then for different pipe sizes the flow for the corresponding pressure (head) drop may be calculated - once one knows the pipe routings - pipe type, number of bends,...
Then at the inlet of the pipe the head can be re-calculated to correspond to the flow. Only there will be a slight complexity there due to the possiblity of vortex formation .
UD15
09/29/2010 9:14 AM
Just guessing:
Since the Vapor Pressure at 21degC is~2.5m it is higher that the 2m differential between the 2 tanks. Therefore, if a big enough diam pipe is used, there could be formation of vapor in big qty to form a plug at some bend in the pipe(?) preventing flow therefore, the levels of the tanks will not become equal.
{I am not familiar with 'Fathom-AFT' warnings}
Good Answers: 137
09/29/2010 2:17 PM
No, vapour pressure 25 mbar = 0.25 m water, not 2.5 m.
Cheers............Codey
09/29/2010 2:48 PM
Sorry, I was just reading the other inputs and picked it as is.
Now I understand that the Op is using a program and is having these results... Well I think that there is some error in the data specified to the program since there should be no problem of cavitation for a pipe flow and no vapor pressure issue since he has a very high water head above the pipe inlet and outle: assuming he is talking about a transfer from the bottom of the 1st tank to the other bottom..
09/29/2010 10:09 AM
Hmmm some curiosities here
Definitely there is an issue with the units (I really dont like MPa, kPa or Pa)
-0.9044 MPa (presumably gauge) equates to -904 kPag or -9barg ie -8barA which is a theoretical pressure.
However the vapour pressure of water at 21°C is 25 mbarA, -0.975barg, -97.5kPag, -0.098 Mpag.
I do love infinite reservoirs they would solve so many problems. Anyway we have two reservoirs with a 2m head between them. As soon as the line is opened water will start to flow from the reservoir wth the higher level to the one with the lower level. I assume the reservoirs are inifinite in lateral dimension so that no matter how much water flows from reservoir A to reservoir B there is still 2m head between them.
I thinkthe issue is the performance with different line sizes.
If you use different line sizes the frictional losses are reduced with larger line sizes for the same flow and so with a fixed head as you would expect the flow increases as the line size increases.
There is a pressure drop in entering the pipe depeding on the shape of the inlet to the pipe. For a typical smoothinlet this is K=0.5 velocity heads. There is also a loss of 1 velocity head for the fluid in the reservoir being at rest and then being accelerated to flowing velocity in the pipe
Head Loss (m) = 1.5 * v^2 / 2 g (g = 9.81 m/2^2)
Although the volumetric flow increases with line size I would expect the velocity to be similar although slowly increasing with line size at a max 2m/s
Head = 0.3m
Pressure Drop = m *SG /10.2 SG = 1.00 for water
Pressure Drop = 0.03 bar = 3 kPa
So in the first few mm of the pipe pressure is 98 kPa(a) 0r -3 kPa
But where is the connecting pipe relative to the water surface - if it were 10m below the surface of the higher reservoir and 8 m below the surface of the lower reservoir then there is 1bar (101kPa) of extra pressure from the depth of water
I think the problem is that somehow the programme thinks that there has been a pressure drop of 0.97 bar which brings the static pressure close to the vapour pressure which would cause cavitation.
The only way I can see this happening is if the connecting pipework goes UP. Now in theory you could siphon between the two reservoirs but it might be impractical in reality but to a PC it might be acceptable but I think that would be the first thing to check
09/29/2010 10:45 AM
I think it is related to the NPSH (Net Positive Suction Head), available. This is calculated from the following:
NPSHa = Habs +/- Hz - Hvp - Hl
Hz= Static head
Hvp= Vapor pressure head
Habs= Atmospheric plus manometric pressure head at the top level of the liquid
Hl= losses in the line due to pipe and fittings
If NPSH of the system is lower than what is required by a pump, than the pump will cavitate. Now since there is no pump there will be no cavitation.
Anything can be made... With time, money and brains.
95324 (1); Anonymous Poster (2); Codemaster (3); LAA_Lucke (2); simonsd (1); Tornado (1)
