Previous in Forum: Layout of Room Containing a Combustion Chamber, Heat Exchanger, Furnace   Next in Forum: Calculation of the Amount of Equalising Water of Boiler Feed Pump Used in Therma
10 comments
Heat Exchanger
09/28/2010 6:22 AM
Which is the best type of heat exchanger that can be used to transfer heat from exhaust gases to compressed air?
Re: heat exchanger
09/28/2010 6:59 AM
Not much info, but why not run your compressed air through coiled copper or aluminum tubing inside a chamber through which you are running your hot exhaust gases?
Re: heat exchanger
09/30/2010 1:22 AM
is there any other way of heating compressed air, maybe electrically or something ??
Re: heat exchanger
09/30/2010 7:10 AM
Lots of ways. It's just going to take some research to determine the most efficient method.
Good Answers: 16
Re: Heat Exchanger
09/28/2010 7:44 AM
Not much info to work with, but the first question(s) that come to my mind are;
Why on earth would one want to make modifications to compress hot air? Or... Are you intending to heat it after its compressed???
Re: Heat Exchanger
09/28/2010 7:52 AM
heating is to be done after the air is compressed.
Re: Heat Exchanger
09/28/2010 9:42 AM
Look here
Only the proper turbulence has to be created for effective heat transfer, which is easier in case of liquids.
For gases yoy may need fins/ corrugations on both inside as well as outside surfaces of the tubes. This is just a bit easier if one uses the plate exchangers rather than tubular.
You may also study something about the heat recovery systems in the powerplant where the flue gas heat is recovered, of course not to compressed air but the Primary Air.
There you are like to have the rotary exchangers (Which of course may not be economical in small scale)
Re: Heat Exchanger
09/28/2010 7:06 PM
finned plate HE
Re: Heat Exchanger
09/28/2010 11:32 PM
thanks for the comments. what kind of pipe can be used to transfer heated compressed air ? how are the pipe dimensions decided ?
Re: Heat Exchanger
09/29/2010 3:01 AM
Did you really expect the heat exchanger to be designed here by us? It is not so simple and now it is no more calculators and slide rules. There are softwares for this purpos.
UD15
Re: Heat Exchanger
09/29/2010 6:31 AM
i mean what material pipe can be used for high temp application (around 800 deg C)
Anonymous Poster (7); kramarat (2); Tim in Mexico (1)
