Previous in Forum: Load Cell Parts   Next in Forum: What is a Corona Ring? What about Discharging?
High RPM DC Motors
03/12/2007 12:10 AM
How would someone design a motor to operate at 48 volts DC and still rotate at 45 thousand RPM's.
Wire gauge up to you .
Other parameters not listed here also up to you.
Pathfinder Tags: DC motors
Re: High RPM DC Motors
03/12/2007 6:37 AM
Another option would be to take a conventional motor and step up its angular velocity using a gearbox.
03/13/2007 5:45 AM
Designing it to operate at 45k rpm's is the easy part. Getting it to actually work reliably is the trick. Also, how much power does it have to output? Is the power source mains or battery? Is it ac or dc? What is it turning? Special manufacturing techniques needed to prevent wire from being thrown out, special bearings and the like.
Other option, get a 12Vdc motor that has a rated speed of around 12,000rpm and feed it 48Vdc. That should do it. But you may need to toughen it up a bit. Centrifugal force is exponential to rpm. Give some more info re: operational parameters.
03/13/2007 5:51 AM
The statement "Centrifugal force is exponential to rpm." is incorrect. "Centrifugal force is proportional to rpm2" is correct.
03/13/2007 8:42 AM
Trying to balance the rotor is going to be a problem at that speed too. Not to mention the bearing requirements. At that rpm the motor is going to have torque issues too. What are you doing that you need to go twice the speed of a turbo charger?
03/13/2007 9:44 AM
Use a permanent magnet rotor with electronically switched fields a much more practical solution. Mechanically designed to take the various forces of coarse.
Try air bearings as against ballraces
Anonymous Poster (1); garth (1); hydman1 (1); PWSlack (2)
