Previous in Forum: Motor Cycle Accidents.   Next in Forum: 2001 Chevy Cavalier Starting Problem
Toyota Premio D4 3S-FSE Engine
09/28/2010 11:28 AM
How do i correct poor idling and engine cutting off after reaching 78 degrees centigrade engine hotness
Re: Toyota Premio D4 3S-FSE Engine
09/28/2010 12:12 PM
how are you measuring temp ?
Most thermostats i know of dont open until 82 degrees c So 78 would be not be normal running temp
Good Answers: 123
09/28/2010 7:55 PM
It might be that there is a vacuum leak. As long as the engine is cold, the vehicle runs at a richer mixture setting. But as the engine reaches normal temperature settings, the system will go to it's leaner settings. That excessive leanness MAY be your problem. But it should be easy to check for. Spray some flammable penetrating oil around the manifold area. If the engine changes how it runs when sprayed, that is your vacuum leak. good luck.
Bob
Good Answers: 60
09/29/2010 5:30 PM
good test method but be carefull in case engine backfires and ignite spray, but yes a good diagnostic tool
Good Answers: 123
10/01/2010 8:48 AM
That also becomes a learned procedure. I have learned to shoot short bursts, and wait for a reaction, before spraying more. The eyebrows should grow back in about 6 months.
Bob
Register to Reply 4 comments
bob c (2); Mech1 (1); peterg7lyq (1)
