Previous in Forum: Lagging in the Transformer   Next in Forum: Protection System in Case of Conductor Failure
India - Member - New Member
Conveyor System Encoder
09/30/2010 9:56 AM
In conveyor system we have encoders still it not taken in line, the same conv working through MM440 drive (siemens), i have no idea to take a encoder in line with drive.
so plz give me a idea for how to taken a encode in line.
Encoder details below
BRN - 5 to 24V, Wht- COMM, Shld - Earth, Grn - CH A &
Yel - CH B
Please hepl me.
Arun Babu
Re: Conveyor System Encoder
09/30/2010 10:10 AM
The MM440 uses sensorless vector control - according to the manual, there is no need or provision for an encoder input.
09/30/2010 10:18 AM
What you have is a quadrature style encoder. This type of an encoder is also known as an incremental encoder. It will tell a processor each incremental step as the encoder moves. Typically this type of an encoder is used in a feedback approach for motion control. Naturally with this being a digital approach, you probably should do a Z transform of your transfer functions to prevent a runaway oscillating condition from closing your feedback system.
That's all the help I can offer from the information you've given. I do not know if you wish the conveyor system to operate at a fixed velocity or to move things on the conveyor to a fixed position.
10/01/2010 9:46 AM
The encoder input is an optional module so and the terminals are well marked so just wire it up according to the labels (assuming your drive has this module installed).
I am not entirely familier with this particular drive but in general, how a drive is setup for encoder feedback depends on what the application is. Speed control - setpoint parameters; pasition control P/PI/PID parameters.
Here is a link that might help:
http://support.automation.siemens.com/WW/llisapi.dll/26436228?func=ll&objId=26436228&objAction=csView&lang=en&siteid=cseus&aktprim=0&extranet=standard&viewreg=WW&load=treecontent
Register to Reply 3 comments
Anonymous Poster (1); JohnDG (1); redfred (1)
You might be interested in: Conveyor Controls and Monitors, Conveyor Rollers
