Previous in Forum: Conveyor System Encoder   Next in Forum: Charging and Monitoring a Lead Acid Battery Using PIC
Protection System in Case of Conductor Failure
09/30/2010 1:34 PM
How can we be sure to safeguard the human life in case of breaking of transmission line live conductor by ensuring tripping of line from both end sources before broken conductor getting earth?
Good Answers: 804
Re: Protection System in Case of Conductor Failure
09/30/2010 7:02 PM
"both end sources"??? What does that mean?
So tell me, who's life is more important, the person under the transmission line that should not have been there but was probably trying to steal copper wire or dismantle the tower braces for the steel scrap, or the thousands of people hooked up to medical equipment that will die if the power to an entire city is cut off to save him, or the fires that will rage because the pumps are shut down, or the accidents that will happen when all the traffic lights go out?
But to answer your question, systems already exist that can do that, however everything we do has consequences... HV transmission protection is complex because it is often a "greatest good" scenario.
09/30/2010 11:19 PM
The weight and inertia of the falling conductor can readily kill some one that is why at construction sites it is mandatory to wear a safety Helmet - Do you have a hard hat on your head?
At the engineering platform methods sech as conductor re-inforcement, Sag and Tension calculations are done to ensure that the conductor does not break even under heavy storms and ice loading conditions.
Intertripping of CB's are regularly applied using microwave, pilot wires, PLCC, fiber optic etc. but the limitation is that the sensing and protection devices have inherent requirement of operation time so as to fulfil a command therefore practically the operation cannot be instantaneous, further system reliability is a prime consideration.
Knowledge sharing is a WIN-WIN situation
Good Answers: 131
10/01/2010 9:27 AM
GA from me, mountk2.
It should be noted that the protection systems used for transmission lines usually trip them within 0.5 second or less, and often in just a few cycles after detecting that a fault has occurred on the line.
10/01/2010 2:47 AM
Sensitive ground fault protection is fairly common to disconnect a distribution power line that has fallen down due to a tree fall, car-VS-pole accident, intentional damage, etc.
Also look up "ground fault neutraliser" (less common, but still quite effective apparently)
jack of all trades (1); JRaef (1); mountk2 (1); PeterT (1)
