Previous in Forum: Oil, Water or What?   Next in Forum: Screw Threads
Good Answers: 34
Change Iconel Type and PWHT
10/01/2010 5:30 AM
We need weld P91 with ss-316L (Pipe to a thermo coupilng). My concerns are about to points:
1. Approved WPS require ERNICR3 (SFA N 5.14), But we have ERNICRMO 3 (Same SFA N 5.14) May I use this filler metal without WPS recualification?
2. Is possible to PWHT at 745ºC the SS- 316L? (For P91 is OK)
Thanks
Engineering Fields - Piping Design Engineering - New Member
Re: Change Iconel Type and PWHT
10/08/2010 3:31 PM
In my opinion, buttering (if possible) of P91 side should be done followed by PWHT. After this, you weld the part to SS316L piping.
You must use ERNiCr-3 although F-numbers of both the wires are same but A-number is different and both are essential variables for GTAW. Or otherwise, re-qualify the welding procedure with ERNiCrMo-3.
Regards,
Ashfaq
http://thepetrostreet.com
