Ferrite as a material has a maximum flux density of 0.3 Tesla or may be in some cases one could go to 0.4 T. Can magnetic flux densities higher than this like 5 or 10 Tesla (in air) be used for say induction welding? One could completely do away with ferrite cores and use only air core- but coils become bulky and need to carry very high current. So can a coil be wound on ferrite cores (it can remain below 0.3T, but the flux emanating from the core be focused using a magnetic lens(!!!???). If the flux density is increased to such high levels- can it be used to replace laser cutting of iron sheets, or butt weld two magnetic sheets (alternative to tig welding?
