I had a problem this week, and was hopping for some feed back from you guys ...
A 6000Volt 1200KW siemens motor the Drive end has a weird like brushing sound emitting from the bearing area. I added grease (Shell alvania RL3) not much, and the temperature of the bearing began to rise... from 71ºC to over 90ºC I had to cool the bearing by forced ventilation to avoid a shutdown.
Later when I had organised a maintenance shutdown we opened the end plate of the bearing, we did not find anything wrong with it. not even over greasing, the bearing rolled smoothly I did notice that someone had regreased the bearing with a BR2 molycoke grease, but both greases are mineral type. We cleaned the bearings and started up the motor... bearing temperatures rose to 85ºC and now after two days of running the temperature is back at 68ºC... but the noise continues... have any of you experienced the same thing or have any theories ?
Thanks in advance
