Previous in Forum: Water Treatment Coagulant   Next in Forum: Evacuation System
I Need a Water Based Adhesive Which Can Stick to PU Foam
10/03/2010 8:35 AM
I am into Self Adhesive Foam parts business in India.
In certain segments, my foams are used to wrap around wire bunches. In this wrap around, the self adhesive side comes in contact with non - adhesive side. It should stick properly and not come off.
For some time it sticks well (say half hour to one hour). Then slowly it starts unwrapping. In this unwrap the adhesive remains where it was (that is, it is not left back, and comes off along with the substrate it was coated on).
I have tried quite a few types, fro India to Italy to USA, but nothing succeeds. I do get partial success by blending a couple of chemicals in certain grades, but the blend is environment sensitive. One blend works well in winter but opens in humid or summer seasons. The other blend works in dry summer but not in winter or rainy season. Similarly, the one which works well in rainy season does not work in dry summer or dry winter !
That means, these blends are both temperature sensitive as well as humidity sensitive.
CR4 Admin - phone number removed
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses.
I can take calls round the clock, even in sleep I can be disturbed because the problem has really really bothered me a lot.
Warme regards,
Ashok Shukla
Re: I need a water based adhesive which can stick to PU Foam
10/03/2010 8:43 AM
Contact these people, I believe they should have something that will fit the bill.
http://www.3m.com/
Re: I Need a Water Based Adhesive Which Can Stick to PU Foam
10/04/2010 12:39 AM
EVA (Ethyl Vinyl Acetate) low melts may answer your need. I too had similar problem but I could over come the same using EVA. These adhesives are solvent free low melting most of them are food grade, very easy to apply, inexpensive and universally available.
If you have any problem sourcing the material in India I will be too pleased to be help. Send me mail through CR4.
10/05/2010 3:29 PM
Dear Mr. Krishnan,
Thank you for the coment.
I sure would like to have a help for this problem.
CR4 Admin –E-mail address removed
Can you please get in touch with me.
Warm regards,
Ashok Shukla
Working Partner
10/05/2010 10:24 PM
Please see rules of CR4
"How do I email a friend / send an internal message? Occasionally, you may want to contact another user to discuss something in greater detail without the prying eyes of the rest of the community. Registered CR4 members can do so by sending an internal message. You can do so by clicking "Send username a message" within his or her profile, or by clicking "Write New Message" from within your own mailbox. Note: this is not an email, but a missive sent within the CR4 system to another user."
10/04/2010 10:25 AM
What is the surface energy of the non-adhesive side? You may need to corona treat.
kramarat (1); krishnan.ng (2); Mikerho (1); SPA_Associates (1)
