Previous in Forum: Air Pressure Regulator   Next in Forum: Application of Extended Diaphragm Sealed Pressure Transmitter
10/05/2010 5:46 AM
I am new in instrumentation, and i have a question, please anybody tell me the application of extended diaphragm seal in process, while we can measure the pressure through flush diaphragm type seal.?
Re: Application of Extended diaphragm seal
10/05/2010 7:04 AM
Is the gauge spaced off the process line by insulation, perhaps?
Good Answers: 29
Re: Application of Extended Diaphragm Seal
10/05/2010 8:59 AM
... or isolation from high or low temperatures?
11/02/2010 2:06 PM
Dear Raees,
If your process is abrassive, corrosive and non-sticky then you can use the flush diaphragm as it will not chock the nozzle on the tank. But if the process is abrassive,corrosive and sticky in nature and can cause you tank nozzle to chock then we will use extended diaphragm. Hope this clears.
Register to Reply 3 comments
PWSlack (1); RAJ KUMAR (1); RDGRNR (1)
