Previous in Forum: Hard Drive Space Reduced After Uninstalling Programs   Next in Forum: IP Address Issue
Winsok Problem
10/05/2010 5:47 AM
Whenever i m try to connect my lan there is a problem in winsock layer what is that how to tackle this problem i already uninstall and install nic or lan card driver.
Good Answers: 29
Re: Winsok Problem
10/05/2010 8:42 AM
This may help.
Re: Winsok Problem
10/06/2010 2:15 AM
what do you means
Re: Winsok Problem
10/10/2010 9:12 AM
try using winsock.netsh in the run command. it will bring back the system to its factory setting if it doesnt work then its time to throw the lan card or may be yur pc and get a new one. I suggest you google the how to use winsock.netsh to get correct syntax.
Register to Reply 3 comments
