Previous in Forum: Application of Extended Diaphragm Sealed Pressure Transmitter   Next in Forum: Level Transmitter Location for Closed Loop Vessel Affect Calc?
Installing RTD's Into Thermowells
10/05/2010 10:46 AM
Does anyone lubricate their 1/4 inch RTD's before puting them into the thermowells. I have had trouble with a few sticking in the past, and was looking for a solution.
Good Answers: 29
Re: Installing RTD's Into Thermowells
10/05/2010 10:57 AM
Depends on where you work. What's allowed. At a pasta factory I worked at, I used food grade white lithium grease. Little dab'll do ya though.
10/06/2010 12:59 PM
There are also thermal mastics, which feature good thermal conductivity.
10/14/2010 7:24 AM
i would use heatsink compound if the temperature permits it is best
Register to Reply 3 comments
RDGRNR (1); Tornado (1); vasant (1)
