I am looking at a pneumatic drive using a rack mounted to a cylinder and a pinion that can free wheel on a shaft, ethir side of the pinion would be a gear that could slide along the shaft but would be keyed in.
The idea being that the gear is pushed against the pinion and then would mesh with a gear welded to the side of the pinion ,when the cylinder extends the pinions turns causing the shaft to turn, on the back stroke the gears DONT mesh ( Like a ratchet ) so the cylinder going in and out causes the shaft to turn in one direction. If the gear on the other side is engauged it would cause the shaft to go in the other direction.
What I would like to know is are there gears around like this and what are they call, and does this idea sound OK
PS I cant us electrics because of fumes.
Thanks
Dave.
