Previous in Forum: Product Engineering for Less   Next in Forum: Angle Calculation
India - Member - New Member
Air Cooler
10/06/2010 1:26 AM
Dear Members,
I have following Information available
- Air Quantity = 63.3 m3/sec.
- Temp. in/out = 48 / 50.4 oC
To calculate the heat load I have done the following :
U - m cp Delta T
m = 63.3 x 28.996/22.4 = 81.93 kg/sec.
cp = 1.009 @ 60 Deg C (kJ/kg K) - Got it from Internet.
Delta t = 2.4
So, based on above formula I have calculated Heat gain by Air = 198 kw.
Is my calculation is correct. OR do I need to consider other important factors.
Regards,
Pathfinder Tags: Oil cooler Cooled by Air
Re: Air cooler
10/06/2010 11:08 AM
Hi Nilesh,
To convert the volumetric flow rate, I used the density of air (values from engineering toolbox on internet) at 50ºC, which was ~1.1 kg/m3. Consequently, the number I got was somewhat lower: 169 kW.
Everything else looks good!
