Previous in Forum: Blower Resistor for Chevy Vehicles   Next in Forum: Electrodyne Alternators
2007 Dodge Diesel 6.7
10/06/2010 7:11 PM
I have a Dodge diesel 6.7 3500
The perform service just came up on the computer at 110k. I service it regulary and when I took it to dodge they said that it was a filter down by the engine. What could this be? Could it be dpf?
Re: 2007 Dodge Diesel 6.7
10/07/2010 12:47 AM
You may have to do a little more diggin. Try CumminsForm.com
a 100 ft chain is not a 100 ft chain if it has a broken link in the middle
Good Answers: 58
10/07/2010 8:58 AM
Could be engine oil, fuel, or tranny oil filter.
If equipped with a charcoal canister it could also be the canister breather filter.
You may also want to try this forum: http://www.cumminsforum.com/forum/6-7l-tech-articles/23063-maintenance-schedule.html
10/08/2010 10:54 AM
Probably. Due to the new emissions requirements, they have lowered the temps in the engine which doesn't allow for sufficient burn-off of the residual carbon. They have added diesel particulate filter downstream on the exhaust side to catch these particles. They then use a DPF sensor to measure when it starts to get filled which will then trigger the system to burn-off the carbon from the filter, essentially cleaning it off for re-use.
It has probably reached the end of its usable service.
KJK/USA (1); Sonave Sunsets (1); Wood I (1)
