Previous in Forum: Why it is considered that R2=R1*1.16 in sqaure wave generator   Next in Forum: Analog or Digital IC
9 comments
How to Design Pulse Generator > 1Mhz?
10/07/2010 1:59 AM
what is the circuit to design a square wave generator with frequency >1Mhz...
Good Answers: 29
Re: How to Design Pulse Generator > 1Mhz?
10/07/2010 8:47 AM
10/07/2010 12:21 PM
I hav desined it before only mut iam getting on millisec range abut i want the timeperiod in micro seconds(i.e in MHz frequency...)
Good Answers: 82
10/09/2010 9:24 AM
The circuit and principle suggested by RDGRNR is fine, just use fast enough parts to do the job. I recommend the TLV3501 (link), with its 4.5ns response. It also has a 30-ohm rail-rail output, which simplifies the circuit. For single-supply operation you can add an extra resistor, as shown in part of fig 7.1 from AoE 3rd edition (right). Just choose R and C small enough for the frequency you want, e.g. 100pF and 909 ohms for 5MHz. I'd drop the values of the other resistors by 5 to 10x.
Thanks, Win
Good Answers: 82
10/10/2010 8:10 AM
One other simple point, Ejaz484, if you want a true square wave, with 50% duty cycle, the standard approach is to make 2 f with your oscillator, and use a divider flip flop to get your perfect square wave.
Thanks, Win
10/12/2010 2:13 AM
Sir can u also say why we need to 3.3eV energy to exicite an electron from valancy band to conduction band when it's bandgap energy is 1.1eV
10/11/2010 12:10 AM
Thanks sir for ur advices and circuits....
10/12/2010 7:49 AM
Sir can u plz explain how this circuit works by explaing significance of each and every component in the circuit please....?
Popular Science - Weaponology - New Member Engineering Fields - Control Engineering - New Member Engineering Fields - Electrical Engineering - New Member
10/30/2010 3:52 AM
you have to design pulse generator with the help of 555 timer ic and not with the help of op-amp because at this the effect of slew rate is coming which distort the square wave.you can simply use 555 timer as a schmitt trigger.
knowledge is increased by sharing!!!!!!!!!!!
Good Answers: 82
11/01/2010 8:49 AM
sajal, you haven't followed up for us on your question, "how to generate high voltage impulses with the help of electronic circuit", in the High Voltage Pulses thread.
Thanks, Win
Register to Reply 9 comments
Ejaz484 (4); RDGRNR (1); sajal mittal (1); Winfield Hill (3)
